Introdução
To gain any access to the internal components of the Dell Vostro 15 5510 the back cover will have to be removed. Once the back cover is removed, you can remove and replace the battery. In order to complete this guide, you will need a Phillips #0 screwdriver head and a plastic opening tool. Ensure to unscrew all screws to prevent any battery or battery input damage.
O que você precisa
Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
Uma outra pessoa concluiu este guia.
