Peças
Não são necessárias peças.
  1. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  2. Pry the base cover along the edges to loosen it.
    • Pry the base cover along the edges to loosen it.
  3. Lift and remove the base cover from the computer.
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Disconnect the battery cable from its connector on the system board.
    • Disconnect the battery cable from its connector on the system board.
  6. Release the tabs that secure the battery in the battery bay.
    • Release the tabs that secure the battery in the battery bay.
  7. Lift and remove the battery from the computer.
    • Lift and remove the battery from the computer.
  8. Pry the retention clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
    • Pry the retention clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
Conclusão
Johnathan Hammond
35.962 reputação
408 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 83
