Ir para o conteúdo principal
Dell Vostro 5480 Battery Replacement
O que você precisa
  1. Dell Vostro 5480 Battery Replacement, Remove the Screws: passo 1, imagem 1 %32
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro 5480 Battery Replacement, Pry the Cover: passo 2, imagem 1 %32
    • Pry the base cover along the edges to loosen it.
  3. Dell Vostro 5480 Battery Replacement, Removing the Base Cover: passo 3, imagem 1 %32
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 5480 Battery Replacement, Disconnecting the Battery Cable: passo 4, imagem 1 %32
    • Disconnect the battery cable from its connector on the system board.
  5. Dell Vostro 5480 Battery Replacement, Release the Tabs: passo 5, imagem 1 %32
    • Release the tabs that secure the battery in the battery bay.
  6. Dell Vostro 5480 Battery Replacement, Removing the Battery: passo 6, imagem 1 %32
    • Lift and remove the battery from the computer.
Linha de Chegada
Johnathan Hammond
Membro desde: 02/28/18
45.237 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 890
