Ir para o conteúdo principal
Dell Vostro 3559 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 3559 Hard Drive Replacement, Sliding the Latch: passo 1, imagem 1 %32
    • Slide the release latch outwards to unlock the battery.
  2. Dell Vostro 3559 Hard Drive Replacement, Remove the Battery: passo 2, imagem 1 %32
    • Remove the battery from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro 3559 Hard Drive Replacement, Remove the Screws: passo 3, imagem 1 %32
    • Remove the screws that secure the access panel to the computer.
    • Lift the access panel partially at a 45–degree angle.
  4. Dell Vostro 3559 Hard Drive Replacement, Remove the Access Panel: passo 4, imagem 1 %32
    • Remove the access panel from the computer.
  5. Dell Vostro 3559 Hard Drive Replacement, Removing the Hard Drive Cable: passo 5, imagem 1 %32
    • Disconnect the hard drive cable from the system board and lift it up to remove it from the computer.
    • Remove the screws that secure the hard drive to the computer.
  6. Dell Vostro 3559 Hard Drive Replacement: passo 6, imagem 1 %32
    • Lift the hard drive to remove it from the computer [1,2].
  7. Dell Vostro 3559 Hard Drive Replacement, Remove the Screws: passo 7, imagem 1 %32
    • Remove the screws that secure the hard drive to the bracket.
    • Lift the hard drive from the bracket.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 433
