Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Slide the release latch outwards to unlock the battery.
Remove the screws that secure the access panel to the computer [1].
Lift the access panel partially at a 45–degree angle [2].
Disconnect the hard drive cable from the system board and lift it up to remove it from the computer.
Remove the screws that secure the hard drive to the computer.
Lift the hard drive to remove it from the computer.
Remove the screws that secure the hard drive to the bracket.
Lift the hard drive from the bracket.
If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Uma outra pessoa concluiu este guia.
Um comentário
Hello. Which hard drive is suitable for replacement of this particular one because mine is no longer working and I don't know anything about hard drive replacements
