Pular para o conteúdo principal
Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
Peças
Nenhum componente especificado.
  1. Slide the release latches to unlock the battery.
    • Slide the release latches to unlock the battery.
  2. Slide the battery and remove it from the computer.
    • Slide the battery and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Remove the screws that secure the access panel to the base of the computer.
    • Remove the screws that secure the access panel to the base of the computer.
  4. Lift the access panel up at an angle and remove it from the computer.
    • Lift the access panel up at an angle and remove it from the computer.
  5. Remove the screws that secure the hard drive to the system.
    • Remove the screws that secure the hard drive to the system.
  6. Lift up the hard drive at an angle from the system and remove.
    • Lift up the hard drive at an angle from the system and remove.
  7. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 28-02-2018
36.011 reputação
408 Guias de autoria
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
930 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Todo: 60
