Ir para o conteúdo principal
Dell Vostro 3550 Display Assembly Replacement
O que você precisa
  1. Dell Vostro 3550 Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32 Dell Vostro 3550 Display Assembly Replacement, Display Assembly: passo 1, imagem 2 %32
    • Grip the back trim of the laptop and pull upwards to remove it.
  2. Dell Vostro 3550 Display Assembly Replacement: passo 2, imagem 1 %32 Dell Vostro 3550 Display Assembly Replacement: passo 2, imagem 2 %32 Dell Vostro 3550 Display Assembly Replacement: passo 2, imagem 3 %32
    • Slide the plastic opening tool around the perimeter of the display bezel.
    • Carefully remove the bezel from the display.
  3. Dell Vostro 3550 Display Assembly Replacement: passo 3, imagem 1 %32 Dell Vostro 3550 Display Assembly Replacement: passo 3, imagem 2 %32 Dell Vostro 3550 Display Assembly Replacement: passo 3, imagem 3 %32
    • Remove the six 7 mm Phillips #0 screws attaching the display to the upper casing of the laptop.
    • When all six screws are removed, gently lower the display to reveal the camera cable.
  4. Dell Vostro 3550 Display Assembly Replacement: passo 4, imagem 1 %32 Dell Vostro 3550 Display Assembly Replacement: passo 4, imagem 2 %32 Dell Vostro 3550 Display Assembly Replacement: passo 4, imagem 3 %32
    • Disconnect the camera ribbon cable by gently pulling it away from its connector.
  5. Dell Vostro 3550 Display Assembly Replacement: passo 5, imagem 1 %32 Dell Vostro 3550 Display Assembly Replacement: passo 5, imagem 2 %32
    • Remove the four 5 mm Phillips #0 screws (two on either side) securing the display to the metal frame.
  6. Dell Vostro 3550 Display Assembly Replacement: passo 6, imagem 1 %32 Dell Vostro 3550 Display Assembly Replacement: passo 6, imagem 2 %32 Dell Vostro 3550 Display Assembly Replacement: passo 6, imagem 3 %32
    • Gently lower the display into a resting position.
  7. Dell Vostro 3550 Display Assembly Replacement: passo 7, imagem 1 %32 Dell Vostro 3550 Display Assembly Replacement: passo 7, imagem 2 %32 Dell Vostro 3550 Display Assembly Replacement: passo 7, imagem 3 %32
    • Loosen the clear tape fastening the ribbon cable to the display.
    • Carefully pull the ribbon cable away from the connector.
  8. Dell Vostro 3550 Display Assembly Replacement: passo 8, imagem 1 %32 Dell Vostro 3550 Display Assembly Replacement: passo 8, imagem 2 %32 Dell Vostro 3550 Display Assembly Replacement: passo 8, imagem 3 %32
    • Peel the ribbon cable away from the display.
    • Remove the display from the laptop.
Conclusão
Dylan J. Souza
Membro desde: 03/22/19
781 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 762
