Ir para o conteúdo principal
Dell Vostro 3550 Disk Drive Tray Latch Replacement
O que você precisa
  1. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: passo 1, imagem 1 %32 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: passo 1, imagem 2 %32 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: passo 1, imagem 3 %32
    • Push a paperclip that is bent straight into the small pin hole on the right of the release button.
    • When 3/4" of the paperclip is inserted the tray will pop open.
    • Pull the disk tray out as far as it will extend.
  2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 2, imagem 1 %32 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 2, imagem 2 %32 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 2, imagem 3 %32
    • Flip the laptop over and position it so the disk drive is in front of you.
    • Remove the five 5mm Phillips #0 screws fastening the top plate to the disk tray.
  3. Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 3, imagem 1 %32 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 3, imagem 2 %32 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 3, imagem 3 %32
    • Remove the top plate of the disk tray and place it off to the side.
  4. Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 4, imagem 1 %32 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 4, imagem 2 %32 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 4, imagem 3 %32
    • Remove the single 5mm Phillips #0 screw securing the latch mechanism to the disk drive.
    • Pull the damaged latch away from the disk drive and replace with the new latch.
Conclusão
Dylan J. Souza
Membro desde: 03/22/19
781 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 249
