Ir para o conteúdo principal
Dell Vostro 3510 Display Replacement
O que você precisa
  1. Dell Vostro 3510 Display Replacement, Display: passo 1, imagem 1 %32 Dell Vostro 3510 Display Replacement, Display: passo 1, imagem 2 %32
    • Ensure the laptop is powered off.
    • Flip the laptop over.
  2. Dell Vostro 3510 Display Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Use a Phillips #0 screwdriver to remove the six 1 mm screws (circled in red).
    • Loosen the two captive 1 mm screws on the back corners.
    • Keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
  3. Dell Vostro 3510 Display Replacement: passo 3, imagem 1 %32 Dell Vostro 3510 Display Replacement: passo 3, imagem 2 %32
    Metal Spudger
    $2.99
    Comprar
    • Open up the back cover of the laptop.
    • It is much easier to open up the laptop with any type of metal spudger or with Jimmy.
  4. Dell Vostro 3510 Display Replacement: passo 4, imagem 1 %32 Dell Vostro 3510 Display Replacement: passo 4, imagem 2 %32 Dell Vostro 3510 Display Replacement: passo 4, imagem 3 %32
    • Start by unplugging the cable for display.
  5. Dell Vostro 3510 Display Replacement: passo 5, imagem 1 %32 Dell Vostro 3510 Display Replacement: passo 5, imagem 2 %32 Dell Vostro 3510 Display Replacement: passo 5, imagem 3 %32
    • Remove the 1 mm screws in red circle with Phillips #0 screwdriver.
  6. Dell Vostro 3510 Display Replacement: passo 6, imagem 1 %32 Dell Vostro 3510 Display Replacement: passo 6, imagem 2 %32
    • Remove the 1 mm screws holding down the metal bracket in red circle with Phillips #0 screwdriver.
  7. Dell Vostro 3510 Display Replacement: passo 7, imagem 1 %32 Dell Vostro 3510 Display Replacement: passo 7, imagem 2 %32
    • Unplug both the white and black wire
    • The black wire is marked in red.
    • The white wire is marked in orange.
  8. Dell Vostro 3510 Display Replacement: passo 8, imagem 1 %32 Dell Vostro 3510 Display Replacement: passo 8, imagem 2 %32 Dell Vostro 3510 Display Replacement: passo 8, imagem 3 %32
    • Lift up the hinges circled in red.
  9. Dell Vostro 3510 Display Replacement: passo 9, imagem 1 %32 Dell Vostro 3510 Display Replacement: passo 9, imagem 2 %32
    • Hold it at a angle and then it should slide off.
Conclusão
Jhoan Cruz
Membro desde: 02/01/24
483 Reputação
Autoria de 3 guias
Equipe
Gateway, Team 16-1, Gonzalez Spring 2024 Membro de Gateway, Team 16-1, Gonzalez Spring 2024
GCC-GONZALEZ-S24S16G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 33
Duração total: 77
