Ir para o conteúdo principal
Dell Vostro 3500 Memory Module Replacement
O que você precisa
  1. Dell Vostro 3500 Memory Module Replacement, Sliding the Battery Latch: passo 1, imagem 1 %32
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3500 Memory Module Replacement, Sliding the Battery Release Latch: passo 2, imagem 1 %32
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3500 Memory Module Replacement, Removing the Battery: passo 3, imagem 1 %32
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3500 Memory Module Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Turn the laptop over and remove two screws securing the service cover.
  5. Dell Vostro 3500 Memory Module Replacement, Removing the Base Cover: passo 5, imagem 1 %32
    • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
    • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
  6. Dell Vostro 3500 Memory Module Replacement, Releasing the Memory Module: passo 6, imagem 1 %32
    • Push apart the memory retention clips to release the memory module.
  7. Dell Vostro 3500 Memory Module Replacement, Remove the Memory Module: passo 7, imagem 1 %32
    • Remove the memory module from its connector on the system board.
Conclusão
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 580
