Ir para o conteúdo principal
Dell Vostro 3500 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 3500 Hard Drive Replacement, Sliding the Battery Latch: passo 1, imagem 1 %32
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3500 Hard Drive Replacement, Sliding the Battery Release Latch: passo 2, imagem 1 %32
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3500 Hard Drive Replacement, Removing the Battery: passo 3, imagem 1 %32
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3500 Hard Drive Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Turn the laptop over and remove two screws securing the service cover.
  5. Dell Vostro 3500 Hard Drive Replacement, Removing the Base Cover: passo 5, imagem 1 %32
    • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
    • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
  6. Dell Vostro 3500 Hard Drive Replacement, Remove the Screws: passo 6, imagem 1 %32
    • Remove the screws that secure the hard-drive assembly to the computer.
  7. Dell Vostro 3500 Hard Drive Replacement, Sliding the Hard-Drive Assembly: passo 7, imagem 1 %32
    • Slide the hard-drive assembly towards the center of the computer.
  8. Dell Vostro 3500 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 8, imagem 1 %32
    • Lift the hard-drive assembly up and away from the computer.
  9. Dell Vostro 3500 Hard Drive Replacement, Remove the Screws: passo 9, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive
  10. Dell Vostro 3500 Hard Drive Replacement, Remove the Hard-Drive Adapter: passo 10, imagem 1 %32
    • Remove the hard-drive adapter from the hard-drive assembly.
  11. Dell Vostro 3500 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 11, imagem 1 %32
    • Lift the hard-drive bracket up and away from the hard drive.
Conclusão
6 outras pessoas executaram este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.820 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 31
Duração total: 5,100
