Introdução
In this guide, we will be showing you how to remove and replace the Palm Rest.
O que você precisa
Slide the left and the right battery release latches to the unlock position.
Pry up the memory door near the screw hole, lift and remove it.
Remove the optical drive bracket from the optical drive module.
Flip the computer around and remove the screws that secures the palm rest.
Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
Release the latch on the system board connector and then disconnect the power button cable.
Release the latch on the system board connector and then disconnect the hot key cable.
Uma outra pessoa concluiu este guia.
