Ir para o conteúdo principal
Dell Vostro 3450 Keyboard Replacement
O que você precisa
  1. Dell Vostro 3450 Keyboard Replacement, Unlocking the Battery: passo 1, imagem 1 %32
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Keyboard Replacement, Removing the Battery: passo 2, imagem 1 %32
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Keyboard Replacement, Prying the Keyboard: passo 3, imagem 1 %32
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  4. Dell Vostro 3450 Keyboard Replacement, Prying the Keyboard retainer: passo 4, imagem 1 %32
    • Pry up the second keyboard retainer.
  5. Dell Vostro 3450 Keyboard Replacement, Pry up the Keyboard Retainer: passo 5, imagem 1 %32
    • Pry up the third keyboard retainer.
  6. Dell Vostro 3450 Keyboard Replacement, Prying the Retainer: passo 6, imagem 1 %32
    • Pry up the fourth keyboard retainer.
  7. Dell Vostro 3450 Keyboard Replacement, Pull up the Keyboard: passo 7, imagem 1 %32
    • Pull up the keyboard from the palm rest.
  8. Dell Vostro 3450 Keyboard Replacement, Release the Latch: passo 8, imagem 1 %32
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
45.058 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.984 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 642
