Ir para o conteúdo principal
Dell Vostro 3400 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 3400 Hard Drive Replacement, Sliding the Battery Release Latch: passo 1, imagem 1 %32
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3400 Hard Drive Replacement, Sliding the Battery Release Latch: passo 2, imagem 1 %32
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3400 Hard Drive Replacement, Sliding the Battery: passo 3, imagem 1 %32
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3400 Hard Drive Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the base cover to the computer.
  5. Dell Vostro 3400 Hard Drive Replacement, Lifting the Base Cover: passo 5, imagem 1 %32
    • Lift up the base cover and remove it from the computer.
  6. Dell Vostro 3400 Hard Drive Replacement, Remove the Screws: passo 6, imagem 1 %32
    • Remove the screws that secure the hard-drive assembly to the computer.
  7. Dell Vostro 3400 Hard Drive Replacement, Sliding the Hard-Drive Assembly: passo 7, imagem 1 %32
    • Slide the hard-drive assembly towards the center of the computer.
  8. Dell Vostro 3400 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 8, imagem 1 %32
    • Lift the hard-drive assembly up and away from the computer.
  9. Dell Vostro 3400 Hard Drive Replacement, Remove the Screws: passo 9, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Vostro 3400 Hard Drive Replacement, Remove the Hard-Drive Adapter: passo 10, imagem 1 %32
    • Remove the hard-drive adapter from the hard-drive assembly.
  11. Dell Vostro 3400 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 11, imagem 1 %32
    • Lift the hard-drive bracket up and away from the hard drive.
Linha de Chegada
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 14
Últimos 30 dias: 20
Duração total: 1,467
