Introdução
In this guide, we will be showing you how to remove and replace the Palm-Rest.
O que você precisa
Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
Lift the clip to release the keyboard cable and disconnect it from the computer.
Remove the screws that secure the display-hinge cover to the computer
Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
Disconnect the power LED cable and the LED board cable from the system board.
Remove the screws that secure the palmrest to the front of the computer.
Pry along the edges of the palmrest to release the palmrest.
Uma outra pessoa concluiu este guia.
