Ir para o conteúdo principal
Dell Vostro 3360 Palm-Rest Replacement
O que você precisa
  1. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screw: passo 1, imagem 1 %32
    • Remove the screw that secures the access panel to the computer.
  2. Dell Vostro 3360 Palm-Rest Replacement, Remove the Access Panel: passo 2, imagem 1 %32
    • Remove the access panel from the computer.
  3. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screw: passo 3, imagem 1 %32
    • Remove the screw that secures the keyboard to the chassis.
  4. Dell Vostro 3360 Palm-Rest Replacement, Prying the Keyboard: passo 4, imagem 1 %32
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  5. Dell Vostro 3360 Palm-Rest Replacement, Flipping the Keyboard: passo 5, imagem 1 %32
    • Flip the keyboard over and lay it on the palmrest.
  6. Dell Vostro 3360 Palm-Rest Replacement, Lifting the Clip: passo 6, imagem 1 %32
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  7. Dell Vostro 3360 Palm-Rest Replacement, Display-Hinge Cover: passo 7, imagem 1 %32
    • Remove the screws that secure the display-hinge cover to the computer
  8. Dell Vostro 3360 Palm-Rest Replacement, Remove the Display Hinge Cover: passo 8, imagem 1 %32
    • Remove the display-hinge cover from the computer.
  9. Dell Vostro 3360 Palm-Rest Replacement, Prying the Rubber Pads: passo 9, imagem 1 %32
    • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
  10. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screws: passo 10, imagem 1 %32
    • Remove the screws that secure the palm-rest to the computer.
  11. Dell Vostro 3360 Palm-Rest Replacement, Disconnecting the Board Cable: passo 11, imagem 1 %32
    • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
  12. Dell Vostro 3360 Palm-Rest Replacement, Disconnecting the LED Cable: passo 12, imagem 1 %32
    • Disconnect the power LED cable and the LED board cable from the system board.
  13. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screws: passo 13, imagem 1 %32
    • Remove the screws that secure the palmrest to the front of the computer.
  14. Dell Vostro 3360 Palm-Rest Replacement, Prying the Edges of the Palm-Rest: passo 14, imagem 1 %32
    • Pry along the edges of the palmrest to release the palmrest.
  15. Dell Vostro 3360 Palm-Rest Replacement, Lifting the Palm Rest: passo 15, imagem 1 %32
    • Lift the palm-rest up and away from the computer.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 204
