Ir para o conteúdo principal
Dell Vostro 2520 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 2520 Hard Drive Replacement, Unlocking the Battery: passo 1, imagem 1 %32
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 2520 Hard Drive Replacement, Removing the Battery: passo 2, imagem 1 %32
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 2520 Hard Drive Replacement, Prying the Tabs: passo 3, imagem 1 %32
    • Pry up to release the tabs securing the keyboard to the computer.
  4. Dell Vostro 2520 Hard Drive Replacement, Flip the Keyboard: passo 4, imagem 1 %32
    • Flip the keyboard and lay it on the palm-rest.
  5. Dell Vostro 2520 Hard Drive Replacement, Disconnect the Cable: passo 5, imagem 1 %32
    • Disconnect the keyboard cable from the system board.
  6. Dell Vostro 2520 Hard Drive Replacement, Remove the Keyboard: passo 6, imagem 1 %32
    • Remove the keyboard from the computer.
  7. Dell Vostro 2520 Hard Drive Replacement, Remove the Screws: passo 7, imagem 1 %32
    • Remove the screws that secure the bottom base.
  8. Dell Vostro 2520 Hard Drive Replacement, Disconnecting the Cable: passo 8, imagem 1 %32
    • Flip the computer and disconnect the power board cable and the touchpad cable.
  9. Dell Vostro 2520 Hard Drive Replacement, Remove the Screws: passo 9, imagem 1 %32
    • Remove the screws that secure the palm-rest to the computer.
  10. Dell Vostro 2520 Hard Drive Replacement, Removing the Palm-Rest: passo 10, imagem 1 %32
    • Starting from the left, pry up the palm-rest and remove it from the computer.
  11. Dell Vostro 2520 Hard Drive Replacement, Remove the Screws: passo 11, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket.
  12. Dell Vostro 2520 Hard Drive Replacement, Lifting the Hard Drive: passo 12, imagem 1 %32
    • Slide and lift the hard drive and lift it out of the computer.
Linha de Chegada
3 outras pessoas executaram este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 19
Duração total: 3,051
