Ir para o conteúdo principal
Dell Vostro 1710 Keyboard Replacement
O que você precisa
  1. Dell Vostro 1710 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Vostro 1710 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dell Vostro 1710 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Dell Vostro 1710 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • Use the plastic opening tool to loosen the plastic hinge cover that is located above the keyboard.
  5. Dell Vostro 1710 Keyboard Replacement: passo 5, imagem 1 %32 Dell Vostro 1710 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove plastic hinge cover by gently lifting up the cover with a plastic opening tool from one side to the other.
  6. Dell Vostro 1710 Keyboard Replacement: passo 6, imagem 1 %32 Dell Vostro 1710 Keyboard Replacement: passo 6, imagem 2 %32
    • Remove the four 3mm Philips #1 head screws.
  7. Dell Vostro 1710 Keyboard Replacement: passo 7, imagem 1 %32 Dell Vostro 1710 Keyboard Replacement: passo 7, imagem 2 %32
    • Gently lift up the keyboard to remove.
    • Flip it over as it shown in the picture.
  8. Dell Vostro 1710 Keyboard Replacement: passo 8, imagem 1 %32 Dell Vostro 1710 Keyboard Replacement: passo 8, imagem 2 %32
    • Lift the black tab that the keyboard is plugged into.
  9. Dell Vostro 1710 Keyboard Replacement: passo 9, imagem 1 %32 Dell Vostro 1710 Keyboard Replacement: passo 9, imagem 2 %32
    • Pull directly outwards to remove the keyboard completely.
Conclusão
Tangxiao Sun
Membro desde: 03/19/18
496 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S3-G7, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G7, Peak Spring 2018
UMASSD-PEAK-S18S3G7
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 659
