Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Press and slide the two buttons outwards and away from the battery.
Slide the battery away and parallel from the laptop.
Unscrew the eight 6mm screws with a Philips #1 screw driver.
Lift back cover from the groove on the left side of the cover next to the symbol.
Unclip the power supply by pulling the cable directly up and out of the socket.
Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
Gently lift and pull to the left until the fan is free from the heatsink.
Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
Lift up on the heatsink to remove it from the laptop.
Uma outra pessoa concluiu este guia.
