Pular para o conteúdo principal
Introdução
The heat sink helps disperse the heat from the laptop, it usually used in conjunction with the fan. If your laptop is overheating, you might need to replace the heatsink. The guide will demonstrate how to replace the heatsink step by step.
Peças
Nenhum componente especificado.
  1. Make certain that the power to your laptop is off. Press and slide the two buttons outwards and away from the battery.
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Slide the battery away and parallel from the laptop.
    • Slide the battery away and parallel from the laptop.
  3. Remove the battery from the slot.
    • Remove the battery from the slot.
  4. Unscrew the eight 6mm screws with a Philips #1 screw driver. Unscrew the eight 6mm screws with a Philips #1 screw driver.
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  6. Lift back cover from the groove on the left side of the cover next to the symbol.
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  7. Unclip the power supply by pulling the cable directly up and out of the socket. Unclip the power supply by pulling the cable directly up and out of the socket.
    • Unclip the power supply by pulling the cable directly up and out of the socket.
  8. Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver. Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
    • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
  9. Gently lift and pull to the left until the fan is free from the heatsink. Gently lift and pull to the left until the fan is free from the heatsink.
    • Gently lift and pull to the left until the fan is free from the heatsink.
  10. Unscrew the four 8mm  screws using a Phillips #1 screwdriver until the heatsink is free. The screws do not come out, only loosen.
    • Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
    • The screws do not come out, only loosen.
  11. Lift up on the heatsink to remove it from the laptop. Lift up on the heatsink to remove it from the laptop.
    • Lift up on the heatsink to remove it from the laptop.
Conclusão
Tangxiao Sun
Membro desde: 19-03-2018
425 reputação
4 Guias de autoria
Equipe
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Todo: 101
