Introdução
The heat sink helps disperse the heat from the laptop, it usually used in conjunction with the fan. If your laptop is overheating, you might need to replace the heatsink. The guide will demonstrate how to replace the heatsink step by step.
Ferramentas
Peças
Não são necessárias peças.
Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
Quase terminado!
Conclusão
