Introdução
The hard drive is the part of the computer that stores all your data including programs, documents, etc. If your laptop is not saving anything you will need to replace your hard drive. This guide can help you remove an old hard drive from the Dell Vostro 1710.
Peças
Não são necessárias peças.
  1. Make certain that the power to your laptop is off. Press and slide the two buttons outwards and away from the battery.
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Slide the battery away and parallel from the laptop.
    • Slide the battery away and parallel from the laptop.
  3. Remove the battery from the slot.
    • Remove the battery from the slot.
  4. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Remove the following five Phillips #1 6mm  screws. Remove the following five Phillips #1 6mm  screws.
    • Remove the following five Phillips #1 6mm screws.
  6. Lift back cover from the groove on the right side of the cover next to the symbol.
    • Lift back cover from the groove on the right side of the cover next to the symbol.
  7. Pull up on the blue tab that is attached to the ribbon cable to unplug it. Pull up on the blue tab that is attached to the ribbon cable to unplug it.
    • Pull up on the blue tab that is attached to the ribbon cable to unplug it.
  8. Remove the three Philips #1 3mm screws. Remove the three Philips #1 3mm screws.
    • Remove the three Philips #1 3mm screws.
  9. Lift and remove the Hard Drive frame by pulling up on the blue tab. Lift and remove the Hard Drive frame by pulling up on the blue tab.
    • Lift and remove the Hard Drive frame by pulling up on the blue tab.
  10. Remove the two 3mm screws with a Philips #1 screwdriver from the back side of the frame to remove the Hard drive. Remove the two 3mm screws with a Philips #1 screwdriver from the back side of the frame to remove the Hard drive.
    • Remove the two 3mm screws with a Philips #1 screwdriver from the back side of the frame to remove the Hard drive.
Conclusão
Jeremy Campeau
313 reputação
3 Guides authored
Equipe
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Todo: 117
