Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Slide both battery latches to the open position.
Slide the battery out of the battery bay.
Loosen the five screws that secure the hard-drive compartment cover.
Remove the cover and set it aside.
Remove the three screws that secure the hard drive to the computer.
Disconnect the hard drive cable connector from the motherboard.
Pull the mylar tab to release the hard drive.
Lift the hard drive and the hard drive cable out of the computer. You may find it easier to lift the hard drive starting from the side located opposite from the hard drive's connection to the hard drive cable.
Uma outra pessoa concluiu este guia.
