Ir para o conteúdo principal
Dell Vostro 1710 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 1710 Hard Drive Replacement, Removing the Battery: passo 1, imagem 1 %32
    • Slide both battery latches to the open position.
    • Slide the battery out of the battery bay.
  2. Dell Vostro 1710 Hard Drive Replacement, Loosen the Screws: passo 2, imagem 1 %32
    • Loosen the five screws that secure the hard-drive compartment cover.
    • Remove the cover and set it aside.
  3. Dell Vostro 1710 Hard Drive Replacement, Removing the Hard Drive Cable: passo 3, imagem 1 %32
    • Remove the three screws that secure the hard drive to the computer.
    • One screw is attached to a metal tab on the metal base of the hard drive, and the other two screws are attached to the metal base.
    • Disconnect the hard drive cable connector from the motherboard.
    • Pull the mylar tab to release the hard drive.
    • Lift the hard drive and the hard drive cable out of the computer. You may find it easier to lift the hard drive starting from the side located opposite from the hard drive's connection to the hard drive cable.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 601
