Ir para o conteúdo principal
Dell Vostro 1700 RAM Replacement
O que você precisa
  1. Dell Vostro 1700 RAM Replacement, Keyboard: passo 1, imagem 1 %32 Dell Vostro 1700 RAM Replacement, Keyboard: passo 1, imagem 2 %32 Dell Vostro 1700 RAM Replacement, Keyboard: passo 1, imagem 3 %32
    • Use the Plastic Opening Tools to pry off the tab located on the right side of the top face plate.
  2. Dell Vostro 1700 RAM Replacement: passo 2, imagem 1 %32
    • Lift the plate off the laptop from right to left.
    • Pull the plate out and remove it.
  3. Dell Vostro 1700 RAM Replacement: passo 3, imagem 1 %32 Dell Vostro 1700 RAM Replacement: passo 3, imagem 2 %32
    • Remove the four 3mm Phillips #0 screws.
  4. Dell Vostro 1700 RAM Replacement: passo 4, imagem 1 %32 Dell Vostro 1700 RAM Replacement: passo 4, imagem 2 %32
    • Grasp the laptop with both hands as shown.
    • Push the keyboard upwards with your thumbs to disconnect it.
  5. Dell Vostro 1700 RAM Replacement: passo 5, imagem 1 %32 Dell Vostro 1700 RAM Replacement: passo 5, imagem 2 %32
    • Lift the keyboard from the laptop and remove it.
    • Ensure the connector is fully disconnected before lifting the keyboard out.
  6. Dell Vostro 1700 RAM Replacement, RAM: passo 6, imagem 1 %32 Dell Vostro 1700 RAM Replacement, RAM: passo 6, imagem 2 %32 Dell Vostro 1700 RAM Replacement, RAM: passo 6, imagem 3 %32
    • Dislodge the RAM from its slot.
    • Push the retaining clips outward with your fingers.
  7. Dell Vostro 1700 RAM Replacement: passo 7, imagem 1 %32 Dell Vostro 1700 RAM Replacement: passo 7, imagem 2 %32 Dell Vostro 1700 RAM Replacement: passo 7, imagem 3 %32
    • Pull the RAM chip up and out.
  8. Dell Vostro 1700 RAM Replacement: passo 8, imagem 1 %32 Dell Vostro 1700 RAM Replacement: passo 8, imagem 2 %32 Dell Vostro 1700 RAM Replacement: passo 8, imagem 3 %32
    • Flip the laptop so under side is facing upwards.
    • Remove the 4.5mm Phillips #1 screw from the RAM cover.
    • Lift off the cover.
  9. Dell Vostro 1700 RAM Replacement: passo 9, imagem 1 %32 Dell Vostro 1700 RAM Replacement: passo 9, imagem 2 %32
    • Dislodge the RAM from its slot by pushing outwards on the retaining clips.
  10. Dell Vostro 1700 RAM Replacement: passo 10, imagem 1 %32 Dell Vostro 1700 RAM Replacement: passo 10, imagem 2 %32 Dell Vostro 1700 RAM Replacement: passo 10, imagem 3 %32
    • Lift the RAM chip up and out of the slot.
Conclusão
Nathan Valm
Membro desde: 03/20/18
735 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G1, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G1, Peak Spring 2018
UMASSD-PEAK-S18S3G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,012
