Introdução
This quick and easy guide will show you how to remove and replace the keyboard on a Dell Vostro 1700 Laptop.
Peças
Não são necessárias peças.
  1. Use the Plastic Opening Tools to pry off the tab located on  the right side of the top face plate. Use the Plastic Opening Tools to pry off the tab located on  the right side of the top face plate. Use the Plastic Opening Tools to pry off the tab located on  the right side of the top face plate.
    • Use the Plastic Opening Tools to pry off the tab located on the right side of the top face plate.
  2. Lift the plate off the laptop from right to left.
    • Lift the plate off the laptop from right to left.
    • Pull the plate out and remove it.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Remove the four 3mm Phillips #0 screws. Remove the four 3mm Phillips #0 screws.
    • Remove the four 3mm Phillips #0 screws.
  5. Grasp the laptop with both hands as shown. Push the keyboard upwards with your thumbs to disconnect it.
    • Grasp the laptop with both hands as shown.
    • Push the keyboard upwards with your thumbs to disconnect it.
  6. Lift the keyboard from the laptop and remove it. Ensure the connector is fully disconnected before lifting the keyboard out.
    • Lift the keyboard from the laptop and remove it.
    • Ensure the connector is fully disconnected before lifting the keyboard out.
Conclusão
Nathan Valm
678 reputação
5 Guides authored
Equipe
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Todo: 51
