Peças
Não são necessárias peças.
  1. Slide the battery lock to the open position.{2}
    • Slide the battery lock to the open position.{2}
      • Slide the battery release latch to the open position. (You may need to hold the battery release latch in the open position while removing the battery.) {3}
        • Slide the battery out of the battery bay.{1}
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Remove the two screws that secure the memory cover, then remove the cover and set it aside.
    • Remove the two screws that secure the memory cover, then remove the cover and set it aside.
  4. NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
      • Remove the memory module from the connector.
Conclusão
Uma outra pessoa concluiu este guia.
Johnathan Hammond
35.962 reputação
408 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 25
