Introdução
This guide shows you how to replace the keyboard. The keyboard is the main input for the laptop. This guide goes through the steps of removing a faulty keyboard.
O que você precisa
Pry the top panel up from the tab in the upper right hand corner.
Run your finger under the panel from right to left to pop it loose.
You might have to tilt back the screen if you are having trouble popping it loose.
