Ir para o conteúdo principal
Dell Vostro 15 KeyBoard Replacement
O que você precisa
  1. Dell Vostro 15 KeyBoard Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latches until they click into place.
    • Slide the battery out of the battery bay.
  2. Dell Vostro 15 KeyBoard Replacement, Hinge Cover: passo 2, imagem 1 %32
    • Open the display all the way so that it rests flat on your work surface.
    • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
  3. Dell Vostro 15 KeyBoard Replacement, KeyBoard: passo 3, imagem 1 %32
    • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
    • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    • Rotate the keyboard connector latch upward to release the keyboard cable.
    • Slide the keyboard cable out of the keyboard connector.
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.953 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 17
Duração total: 377
