Ir para o conteúdo principal
Dell Vostro 15 5568 Back Cover Replacement
O que você precisa
  1. Dell Vostro 15 5568 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the screws that secure the back cover to the computer.
  2. Dell Vostro 15 5568 Back Cover Replacement: passo 2, imagem 1 %32
    • Using a scribe, pry the edges of the back cover from all sides [1].
    • Lift the back cover from the computer [2].
    Orientation: the bottom of the laptop facing up, hinge on the opposite side from you.
    Be careful if you want to open up the screen after undoing the top left corner screw. This is the only screw on this side attaching the hinge to the baseplate, so if it's removed, the hinge might pry up the corner (upon opening the laptop).
    This can also aid in creating the first gap where you can insert a prytool.
    kepeter97 - Responder
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.820 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
Um comentário
hi my backcover for dell vostro 5568 is broken can you suggest some website for purchasing it
Vinith Velan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 1,026
