Ir para o conteúdo principal
Dell Vostro 15 3568 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 15 3568 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3568 Hard Drive Replacement, KeyBoard: passo 2, imagem 1 %32
    • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
  3. Dell Vostro 15 3568 Hard Drive Replacement: passo 3, imagem 1 %32
    • Disconnect the keyboard cable from the system board.
    • Lift the keyboard cable to remove it from the computer.
  4. Dell Vostro 15 3568 Hard Drive Replacement, Base Cover: passo 4, imagem 1 %32
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the screws inside the palmrest [2].
  5. Dell Vostro 15 3568 Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the screws that secure the base cover to the computer
  6. Dell Vostro 15 3568 Hard Drive Replacement: passo 6, imagem 1 %32
    • Pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  7. Dell Vostro 15 3568 Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32
    • Disconnect the hard drive cable from the connector on the system board [1].
    • Remove the screws that secure the hard drive assembly to the computer [2].
    • Lift the hard drive assembly away from the computer [3].
Conclusão
16 outras pessoas executaram este guia.
Johnathan Hammond
Membro desde: 02/28/18
45.034 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 20
Últimos 30 dias: 129
Duração total: 16,326
