Ir para o conteúdo principal
Dell Vostro 15 3565 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 15 3565 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3565 Hard Drive Replacement, Optical-Disk Drive: passo 2, imagem 1 %32
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 15 3565 Hard Drive Replacement, KeyBoard: passo 3, imagem 1 %32
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. Dell Vostro 15 3565 Hard Drive Replacement: passo 4, imagem 1 %32
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  5. Dell Vostro 15 3565 Hard Drive Replacement: passo 5, imagem 1 %32
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  6. Dell Vostro 15 3565 Hard Drive Replacement, Base Cover: passo 6, imagem 1 %32
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  7. Dell Vostro 15 3565 Hard Drive Replacement: passo 7, imagem 1 %32
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
  8. Dell Vostro 15 3565 Hard Drive Replacement, Hard Drive: passo 8, imagem 1 %32
    • Disconnect the hard drive cable from the connector on the system board [1, 2].
    • Remove the screws that secure the hard drive assembly to the computer [3].
    • Lift the hard drive assembly away from the computer [4].
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 131
