Ir para o conteúdo principal
Dell Vostro 1450 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 1450 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 1450 Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 1450 Hard Drive Replacement, KeyBoard: passo 3, imagem 1 %32
    • Pry up to release the top four snaps securing the keyboard to the computer.
  4. Dell Vostro 1450 Hard Drive Replacement: passo 4, imagem 1 %32
    • Flip the keyboard over and lay it on the palm rest.
  5. Dell Vostro 1450 Hard Drive Replacement: passo 5, imagem 1 %32
    • Disconnect the keyboard cable from the system board.
  6. Dell Vostro 1450 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the keyboard from the computer.
  7. Dell Vostro 1450 Hard Drive Replacement, Palm Rest: passo 7, imagem 1 %32
    • Remove the screws that secure the bottom base.
  8. Dell Vostro 1450 Hard Drive Replacement: passo 8, imagem 1 %32
    • Flip the computer around and disconnect the power board cable (1) and the touchpad cable (2).
  9. Dell Vostro 1450 Hard Drive Replacement: passo 9, imagem 1 %32
    • Remove the screws that secure the palm rest to the computer.
  10. Dell Vostro 1450 Hard Drive Replacement: passo 10, imagem 1 %32
    • Pry up the palm rest using a plastic scribe to release all the snaps on the bottom, left, and right sides of the palm rest. Once all the snaps have been released, lift up the palm rest from the computer and remove.
  11. Dell Vostro 1450 Hard Drive Replacement, Hard Drive: passo 11, imagem 1 %32
    • Slide the hard drive and lift it out of the computer.
  12. Dell Vostro 1450 Hard Drive Replacement: passo 12, imagem 1 %32
    • Remove the screws that secure the hard drive bracket and detach it from the hard drive.
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,086
