Ir para o conteúdo principal
Dell Vostro 1400 Speakers Replacement
O que você precisa
  1. Dell Vostro 1400 Speakers Replacement, Battery: passo 1, imagem 1 %32
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Speakers Replacement: passo 2, imagem 1 %32
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Speakers Replacement: passo 3, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 3, imagem 2 %32
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Speakers Replacement, Hard Drive: passo 4, imagem 1 %32 Dell Vostro 1400 Speakers Replacement, Hard Drive: passo 4, imagem 2 %32
    • Please ensure that your device is turned off and everything is unplugged before working on it.
    • Unscrew both screws on the hard drive panel until the panel is able to be removed.
    • The screws will not come off of the panel.
    • Once screws have been loosened, remove the panel from the laptop.
  5. Dell Vostro 1400 Speakers Replacement: passo 5, imagem 1 %32
    • Remove the hard drive by pulling up on the black tab on the right side of the hard drive.
  6. Dell Vostro 1400 Speakers Replacement, RAM: passo 6, imagem 1 %32 Dell Vostro 1400 Speakers Replacement, RAM: passo 6, imagem 2 %32
    • Make sure the laptop is turned off and all cables are unplugged.
    • Loosen the three 3 mm screws on the RAM cover.
    • Screws will not completely come out.
    • Lift the cover and remove it from the laptop.
  7. Dell Vostro 1400 Speakers Replacement: passo 7, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 7, imagem 2 %32
    • Pull tabs apart on both the top and bottom of the memory card.
    • Lift memory card and remove it from the laptop.
    • Repeat the process for the second memory card.
  8. Dell Vostro 1400 Speakers Replacement, Speakers: passo 8, imagem 1 %32 Dell Vostro 1400 Speakers Replacement, Speakers: passo 8, imagem 2 %32 Dell Vostro 1400 Speakers Replacement, Speakers: passo 8, imagem 3 %32
    • Make sure device is turned off
    • Loosen the 3 screws holding down the panel for the CPU processor door.
    • Loosen the 4 heat sink screws and lift the heat sink away from the motherboard.
  9. Dell Vostro 1400 Speakers Replacement: passo 9, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 9, imagem 2 %32
    • Use a flat head screw driver to turn the CPU locking screw counter clockwise to 180 degrees.
    • Lift CPU processor away from the motherboard
  10. Dell Vostro 1400 Speakers Replacement: passo 10, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 10, imagem 2 %32
    • Remove the seventeen 8mm bottom base screws.
    • Remove the two 8mm screws from the back.
  11. Dell Vostro 1400 Speakers Replacement: passo 11, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 11, imagem 2 %32
    • Remove the three 3mm bottom base screws.
    • Remove the 5mm bottom base screw.
  12. Dell Vostro 1400 Speakers Replacement: passo 12, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 12, imagem 2 %32
    • Turn over the laptop and open it.
    • Using a flat head screw driver, pry up the power button cover starting right to left.
  13. Dell Vostro 1400 Speakers Replacement: passo 13, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 13, imagem 2 %32
    • Unscrew the (2) 2mm x 3mm screws.
    • Carefully lift the keyboard and hold it over the power button.
  14. Dell Vostro 1400 Speakers Replacement: passo 14, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 14, imagem 2 %32 Dell Vostro 1400 Speakers Replacement: passo 14, imagem 3 %32
    • Carefully lift up the blue latch on the keyboard cable connector and slide the cable out.
  15. Dell Vostro 1400 Speakers Replacement: passo 15, imagem 1 %32
    • Remove the left and the right hinge covers.
  16. Dell Vostro 1400 Speakers Replacement: passo 16, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 16, imagem 2 %32 Dell Vostro 1400 Speakers Replacement: passo 16, imagem 3 %32
    • Unplug the WLAN antenna cables.
    • Unscrew the 2mm x 3mm screw.
    • Remove the WLAN card from the motherboard.
  17. Dell Vostro 1400 Speakers Replacement: passo 17, imagem 1 %32
    • Remove the 2mm x 3mm screw on the media button circuit board.
    • Loosen the media button circuit board and take the antenna cables from under it.
  18. Dell Vostro 1400 Speakers Replacement: passo 18, imagem 1 %32
    • Unplug LCD cable
    • Lift LCD assembly away from the laptop
  19. Dell Vostro 1400 Speakers Replacement: passo 19, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 19, imagem 2 %32
    • Remove the (3) 2.5mm x 5mm top palmrest screws
    • Unplug palm rest cables
  20. Dell Vostro 1400 Speakers Replacement: passo 20, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 20, imagem 2 %32
    • Remove the palm rest from the base of the laptop
  21. Dell Vostro 1400 Speakers Replacement: passo 21, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 21, imagem 2 %32 Dell Vostro 1400 Speakers Replacement: passo 21, imagem 3 %32
    • Unplug the audio board cable and the speakers.
    • Remove the 2.5mm x 5mm screw.
  22. Dell Vostro 1400 Speakers Replacement: passo 22, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 22, imagem 2 %32 Dell Vostro 1400 Speakers Replacement: passo 22, imagem 3 %32
    • Remove the (2) 2mm x 3mm screws.
    • Lift the motherboard out of the base and flip it over.
  23. Dell Vostro 1400 Speakers Replacement: passo 23, imagem 1 %32 Dell Vostro 1400 Speakers Replacement: passo 23, imagem 2 %32 Dell Vostro 1400 Speakers Replacement: passo 23, imagem 3 %32
    • Remove the two 2.5mm x 5mm Right and Left speaker screws
    • Lift the speakers away from the base of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
David Hogg
Membro desde: 03/20/17
739 Reputação
Autoria de 5 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 15
Ao todo: 1,059
