Ir para o conteúdo principal
Dell Vostro 1400 Screen Replacement
O que você precisa
  1. Dell Vostro 1400 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Screen Replacement: passo 2, imagem 1 %32
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Screen Replacement: passo 3, imagem 1 %32 Dell Vostro 1400 Screen Replacement: passo 3, imagem 2 %32
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Screen Replacement, Screen: passo 4, imagem 1 %32
    • Please make sure your device is completely turned off and everything is unplugged from the device
    • Open the laptop.
  5. Dell Vostro 1400 Screen Replacement: passo 5, imagem 1 %32 Dell Vostro 1400 Screen Replacement: passo 5, imagem 2 %32
    • Remove the 6 screw hole covers surrounding the screen.
    • Remove the 6 screws that were underneath the screw covers.
  6. Dell Vostro 1400 Screen Replacement: passo 6, imagem 1 %32 Dell Vostro 1400 Screen Replacement: passo 6, imagem 2 %32
    • Carefully remove the plastic surrounding the screen by pulling off, starting at the bottom.
    • Remove the two (2.5mm x 5mm) screws at the top, by the camera.
  7. Dell Vostro 1400 Screen Replacement: passo 7, imagem 1 %32 Dell Vostro 1400 Screen Replacement: passo 7, imagem 2 %32
    • Remove the two 5mm screws from the camera above the screen.
    • Remove the two 5mm screws from the bottom of the screen.
  8. Dell Vostro 1400 Screen Replacement: passo 8, imagem 1 %32 Dell Vostro 1400 Screen Replacement: passo 8, imagem 2 %32
    • Carefully remove the screen from the back cover.
  9. Dell Vostro 1400 Screen Replacement: passo 9, imagem 1 %32 Dell Vostro 1400 Screen Replacement: passo 9, imagem 2 %32
    • Lift up the black tag holding the camera and cable together.
    • Unplug the camera from the cable.
  10. Dell Vostro 1400 Screen Replacement: passo 10, imagem 1 %32 Dell Vostro 1400 Screen Replacement: passo 10, imagem 2 %32 Dell Vostro 1400 Screen Replacement: passo 10, imagem 3 %32
    • Unplug the two cables connected to the screen.
  11. Dell Vostro 1400 Screen Replacement: passo 11, imagem 1 %32 Dell Vostro 1400 Screen Replacement: passo 11, imagem 2 %32
    • Remove the six 3mm screws on each side of the screen.
    • Remove the railing on each side of the screen.
    • The railing will be marked "L" for left side or "R" for the right. This should assist in reassembly.
Conclusão
David Hogg
Membro desde: 03/20/17
739 Reputação
Autoria de 5 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 685
