Ir para o conteúdo principal
Dell Vostro 1400 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 1400 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Hard Drive Replacement: passo 2, imagem 1 %32
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Vostro 1400 Hard Drive Replacement: passo 3, imagem 2 %32
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Dell Vostro 1400 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Please ensure that your device is turned off and everything is unplugged before working on it.
    • Unscrew both screws on the hard drive panel until the panel is able to be removed.
    • The screws will not come off of the panel.
    • Once screws have been loosened, remove the panel from the laptop.
  5. Dell Vostro 1400 Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the hard drive by pulling up on the black tab on the right side of the hard drive.
Conclusão
David Hogg
Membro desde: 03/20/17
739 Reputação
Autoria de 5 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 13
Ao todo: 753
