Peças
Não são necessárias peças.
  1. Slide the release latch to unlock the battery [1].
    • Slide the release latch to unlock the battery [1].
      • Remove the battery from the computer [2].
  2. Remove the screw that secures the optical drive to the computer [1].
    • Remove the screw that secures the optical drive to the computer [1].
      • Using a plastic scribe, push the tab to release the optical drive [2].
        • Slide the optical drive out of the computer [3].
  3. Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Disconnect the keyboard cable from the system board.
    • Disconnect the keyboard cable from the system board.
      • Lift the keyboard cable to remove it from the computer.
  6. Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
      • Remove the screws inside the palmrest [2].
  7. Remove the screws that secure the base cover to the computer
    • Remove the screws that secure the base cover to the computer
  8. Pry the edges of the base cover [1].
    • Pry the edges of the base cover [1].
      • Lift the base cover and remove it from the computer [2].
Conclusão
Johnathan Hammond
35.962 reputação
408 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 92
