Ir para o conteúdo principal
Dell Vostro 1320 USB Port Replacement
O que você precisa
  1. Dell Vostro 1320 USB Port Replacement, USB Port: passo 1, imagem 1 %32
    • Remove the battery from the computer.
  2. Dell Vostro 1320 USB Port Replacement: passo 2, imagem 1 %32
    • Remove all visible screws from the bottom of the computer.
  3. Dell Vostro 1320 USB Port Replacement: passo 3, imagem 1 %32 Dell Vostro 1320 USB Port Replacement: passo 3, imagem 2 %32 Dell Vostro 1320 USB Port Replacement: passo 3, imagem 3 %32
    • Use a metal spudger to remover the covers of each section that you removed screws from.
    • Once the cover is removed from the hard drive remove the hard drive by gently tugging it out.
  4. Dell Vostro 1320 USB Port Replacement: passo 4, imagem 1 %32
  5. Dell Vostro 1320 USB Port Replacement: passo 5, imagem 1 %32 Dell Vostro 1320 USB Port Replacement: passo 5, imagem 2 %32 Dell Vostro 1320 USB Port Replacement: passo 5, imagem 3 %32
    • You must first unscrew the screws holding the wire in place.
    • Unhook the wire that the metal spudger is pointing at.
  6. Dell Vostro 1320 USB Port Replacement: passo 6, imagem 1 %32
  7. Dell Vostro 1320 USB Port Replacement: passo 7, imagem 1 %32 Dell Vostro 1320 USB Port Replacement: passo 7, imagem 2 %32
    • Undo the screws holding the screen to the computer base.
  8. Dell Vostro 1320 USB Port Replacement: passo 8, imagem 1 %32
    • Unplug the wires connecting the screen to the base.
    • The screen should come free and is able to be removed completely.
  9. Dell Vostro 1320 USB Port Replacement: passo 9, imagem 1 %32 Dell Vostro 1320 USB Port Replacement: passo 9, imagem 2 %32
    • Unplug the two blue labeled wires.
  10. Dell Vostro 1320 USB Port Replacement: passo 10, imagem 1 %32 Dell Vostro 1320 USB Port Replacement: passo 10, imagem 2 %32 Dell Vostro 1320 USB Port Replacement: passo 10, imagem 3 %32
    • Detach the black plastic cover by loosening it with a metal spudger.
  11. Dell Vostro 1320 USB Port Replacement: passo 11, imagem 1 %32
    • Unplug the wire that the metal spudger is pointing to.
  12. Dell Vostro 1320 USB Port Replacement: passo 12, imagem 1 %32
    • Unscrew the USB port.
  13. Dell Vostro 1320 USB Port Replacement: passo 13, imagem 1 %32 Dell Vostro 1320 USB Port Replacement: passo 13, imagem 2 %32
    • Gently lift out the USB port.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 628
