Ir para o conteúdo principal
Dell Vostro 1310 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 1310 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery lock to the open position. {2}
    • Slide the battery latch release to the open position. (You may need to hold the latch release in the open position while removing the battery.){3}
    • Slide the battery out of the battery bay. {1}
  2. Dell Vostro 1310 Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32
    • Remove the M2.5 x 5-mm screw that secures the hard-drive compartment cover. {2}
    • Remove the cover and set it aside.{1}
  3. Dell Vostro 1310 Hard Drive Replacement: passo 3, imagem 1 %32
    • NOTICE: When the hard drive is not in the computer, store the drive in protective antistatic packaging.
    • Remove the two screws securing the hard drive to the hard-drive bracket.
    • Slide the hard drive out of the hard-drive bracket.
    • Pull the mylar tab to release the hard drive.
    • Lift the hard drive out of the computer.
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.820 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 386
