Ir para o conteúdo principal
Dell Vostro 1088 Hard Drive Replacement
O que você precisa
  1. Dell Vostro 1088 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Vostro 1088 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery latches apart while at the same time slipping your forefingers into the groove at the center of the battery and pushing outward to disengage the battery from the computer.
    • Lift the battery from the computer.
  2. Dell Vostro 1088 Hard Drive Replacement, Access Panel: passo 2, imagem 1 %32 Dell Vostro 1088 Hard Drive Replacement, Access Panel: passo 2, imagem 2 %32
    • Remove the six screws that secure the access panel to the computer.
    • Remove the access panel from the computer.
  3. Dell Vostro 1088 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Dell Vostro 1088 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Remove the four screws that secure the hard drive assembly to the computer.
    • Pull the plastic tab toward the opposite end of the hard drive assembly to disengage the hard drive interposer from the connector on the system board, then lift the hard drive assembly from the computer.
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 158
