Ir para o conteúdo principal
Dell Vostro 1000 Memory Module Replacement
O que você precisa
  1. Dell Vostro 1000 Memory Module Replacement, Battery: passo 1, imagem 1 %32
    • Slide and hold the battery-bay latch release on the bottom of the computer, and then lift the battery from the bay.
  2. Dell Vostro 1000 Memory Module Replacement, Memory Module: passo 2, imagem 1 %32
    • loosen the captive screws on the memory module cover, and then remove the memory module cover.
  3. Dell Vostro 1000 Memory Module Replacement: passo 3, imagem 1 %32
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the memory-module securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.953 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 201
