Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
We will be removing the outer cover of the Dell Venue 8, which will expose the plastic back cover which we will also be taking off. These two pieces are necessary to remove to make any major repairs to the Dell Venue 8.
O que você precisa
Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
Remove the back panel of the device.
7 outras pessoas executaram este guia.
