Ir para o conteúdo principal
Dell Venue 8 Front Camera Replacement
O que você precisa
  1. Dell Venue 8 Front Camera Replacement, Rear Case/Midframe: passo 1, imagem 1 %32
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Front Camera Replacement: passo 2, imagem 1 %32 Dell Venue 8 Front Camera Replacement: passo 2, imagem 2 %32 Dell Venue 8 Front Camera Replacement: passo 2, imagem 3 %32
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Front Camera Replacement, Front Camera: passo 3, imagem 1 %32 Dell Venue 8 Front Camera Replacement, Front Camera: passo 3, imagem 2 %32
    • The front-facing camera is located just above the rear-facing camera.
    • Pull the connection tab up, unclipping it.
    • Pull up on the front camera, and the adhesive will release.
Conclusão
Andrea
Membro desde: 02/19/15
1.071 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 9-2, Leahy Winter 2015 Membro de USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 500
