Ir para o conteúdo principal
Dell Venue 8 Display Replacement
O que você precisa
  1. Dell Venue 8 Display Replacement, Rear Case/Midframe: passo 1, imagem 1 %32
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Display Replacement: passo 2, imagem 1 %32 Dell Venue 8 Display Replacement: passo 2, imagem 2 %32 Dell Venue 8 Display Replacement: passo 2, imagem 3 %32
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Display Replacement, Battery: passo 3, imagem 1 %32
    • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
  4. Dell Venue 8 Display Replacement: passo 4, imagem 1 %32
    • Gently pry the battery away from the device with the plastic opening tool to remove it.
    • The battery is held on to the tablet by a light adhesive
  5. Dell Venue 8 Display Replacement, Speaker: passo 5, imagem 1 %32
    • Using your plastic opening tool, unclip the speaker connection from the logic board.
    • Caution: Pull directly up, not out, on the connection
  6. Dell Venue 8 Display Replacement: passo 6, imagem 1 %32
    • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
    • The speaker is held on by light adhesive
  7. Dell Venue 8 Display Replacement, Display: passo 7, imagem 1 %32 Dell Venue 8 Display Replacement, Display: passo 7, imagem 2 %32
    • Disconnect the display clip found next to the speaker.
    • Disconnect the Display connection located at the top of the tablet.
  8. Dell Venue 8 Display Replacement: passo 8, imagem 1 %32
    • Unclip the logic board from the Display.
Conclusão
7 outras pessoas executaram este guia.
Mitul
Membro desde: 02/19/15
673 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 9-2, Leahy Winter 2015 Membro de USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
Membros da 3
Autoria de 12 guias
2 comentários
LOL. Who rated this as a difficult repair? Seriously? T5 screws too much for you? The only issue with the repair for this device is the adhesive between the digi and frame is a REAL pain to remove, and the plastic frame is likely to melt if you use too much/high heat. Otherwise, it's very simple. Just be careful when installing the new digi, as the motherboard needs to be slightly lifted to feed the connector.
Rene - Responder
Thanks for the instructions!
Is there a part 2 for this guide? The instructions is incomplete and doesn't not include steps to actually remove the digitizer.
Franklin Ramos - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 7,115
