Introdução
If your camera isnt functioning properly, not showing a display, or looks cracked or foggy, it may need to be replaced. In this guide we will be replacing the rear-facing camera.
O que você precisa
Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
Remove the back panel of the device.
Use the plastic opening tool to disconnect the camera from the logic board, by prying it up.
Uma outra pessoa concluiu este guia.
