Introdução
Many components are connected to the motherboard so confirm that all of the components work before you decide to replace the whole motherboard.
O que você precisa
Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
Gently pull on the wire and remove the speaker.
When I was pulling the speaker out the wire had broken where can I get the speaker?
Disconnect the two remaining connections on the motherboard.
To remove the first connector, lift up the clasp and remove the ribbon cable.
To remove the second one, use a spudger to gently pry the connector from the motherboard.
8 outras pessoas executaram este guia.
2 comentários
unable to open the lock, can the mother board be changed
Great article.
