Ir para o conteúdo principal
Dell Venue 7 Motherboard Replacement
O que você precisa
  1. Dell Venue 7 Motherboard Replacement, Rear Case: passo 1, imagem 1 %32 Dell Venue 7 Motherboard Replacement, Rear Case: passo 1, imagem 2 %32
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Motherboard Replacement, Battery: passo 2, imagem 1 %32
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Motherboard Replacement, Rear Facing Camera: passo 4, imagem 1 %32
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the camera from the device.
  6. Dell Venue 7 Motherboard Replacement, Speaker: passo 6, imagem 1 %32 Dell Venue 7 Motherboard Replacement, Speaker: passo 6, imagem 2 %32
    • Use a spudger to remove the ribbon cable that is around the speaker wire.
  7. Dell Venue 7 Motherboard Replacement: passo 7, imagem 1 %32 Dell Venue 7 Motherboard Replacement: passo 7, imagem 2 %32
    • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
  8. Dell Venue 7 Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the plastic covering on the speaker.
  9. Dell Venue 7 Motherboard Replacement: passo 9, imagem 1 %32 Dell Venue 7 Motherboard Replacement: passo 9, imagem 2 %32
    • Gently pull on the wire and remove the speaker.
  10. Dell Venue 7 Motherboard Replacement, Motherboard: passo 10, imagem 1 %32 Dell Venue 7 Motherboard Replacement, Motherboard: passo 10, imagem 2 %32 Dell Venue 7 Motherboard Replacement, Motherboard: passo 10, imagem 3 %32
    • Disconnect the two remaining connections on the motherboard.
    • To remove the first connector, lift up the clasp and remove the ribbon cable.
    • To remove the second one, use a spudger to gently pry the connector from the motherboard.
  11. Dell Venue 7 Motherboard Replacement: passo 11, imagem 1 %32 Dell Venue 7 Motherboard Replacement: passo 11, imagem 2 %32
    • Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
  12. Dell Venue 7 Motherboard Replacement: passo 12, imagem 1 %32
    • Lift and remove the motherboard from the device.
Conclusão
8 outras pessoas executaram este guia.
Stephen Rousseau
Membro desde: 01/20/15
663 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 11-4, Blackwell Winter 2015 Membro de USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
Membros da 4
Autoria de 10 guias
2 comentários
unable to open the lock, can the mother board be changed
Amitabh Mishra - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 4,410
