Ir para o conteúdo principal
Dell VRP100 Lens Replacement
O que você precisa
  1. Dell VRP100 Lens Replacement, Cover Panel: passo 1, imagem 1 %32 Dell VRP100 Lens Replacement, Cover Panel: passo 1, imagem 2 %32 Dell VRP100 Lens Replacement, Cover Panel: passo 1, imagem 3 %32
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
    Pergunte ao FixBot
    Comentar
  2. Dell VRP100 Lens Replacement: passo 2, imagem 1 %32
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
    Pergunte ao FixBot
    Comentar
  3. Dell VRP100 Lens Replacement: passo 3, imagem 1 %32 Dell VRP100 Lens Replacement: passo 3, imagem 2 %32 Dell VRP100 Lens Replacement: passo 3, imagem 3 %32
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
    Pergunte ao FixBot
    Comentar
  4. Dell VRP100 Lens Replacement: passo 4, imagem 1 %32 Dell VRP100 Lens Replacement: passo 4, imagem 2 %32 Dell VRP100 Lens Replacement: passo 4, imagem 3 %32
    • Carefully remove the lens and motherboard assembly from the white casing.
    Pergunte ao FixBot
    Comentar
  5. Dell VRP100 Lens Replacement, Lens: passo 5, imagem 1 %32 Dell VRP100 Lens Replacement, Lens: passo 5, imagem 2 %32
    • Deattach the black cover from the lens with a metal spudger.
    • This will “click” back into place during replacement.
    Pergunte ao FixBot
    Comentar
  6. Dell VRP100 Lens Replacement: passo 6, imagem 1 %32 Dell VRP100 Lens Replacement: passo 6, imagem 2 %32 Dell VRP100 Lens Replacement: passo 6, imagem 3 %32
    • Gently insert the metal spudger between the lens and the lens casing.
    • Rotate the spudger around the exterior of the lens and lens housing, separating them.
    • The lens is held in place with an adhesive that will have to be applied during reassembly.
    Pergunte ao FixBot
    Comentar
  7. Dell VRP100 Lens Replacement: passo 7, imagem 1 %32
    • Holding the lens around the outside, gently lift it out of its housing.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Chris Grabow
Membro desde: 10/08/18
285 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G1, White Fall 2018 Membro de Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 41
Ao todo: 1,180
