Ir para o conteúdo principal
Dell VRP100 HDMI/USB Cable Replacement
O que você precisa
  1. Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: passo 1, imagem 1 %32 Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: passo 1, imagem 2 %32 Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: passo 1, imagem 3 %32
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
    Pergunte ao FixBot
    Comentar
  2. Dell VRP100 HDMI/USB Cable Replacement: passo 2, imagem 1 %32
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
    Pergunte ao FixBot
    Comentar
  3. Dell VRP100 HDMI/USB Cable Replacement: passo 3, imagem 1 %32 Dell VRP100 HDMI/USB Cable Replacement: passo 3, imagem 2 %32 Dell VRP100 HDMI/USB Cable Replacement: passo 3, imagem 3 %32
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
    Pergunte ao FixBot
    Comentar
  4. Dell VRP100 HDMI/USB Cable Replacement: passo 4, imagem 1 %32 Dell VRP100 HDMI/USB Cable Replacement: passo 4, imagem 2 %32 Dell VRP100 HDMI/USB Cable Replacement: passo 4, imagem 3 %32
    • Carefully remove the lens and motherboard assembly from the white casing.
    Pergunte ao FixBot
    Comentar
  5. Dell VRP100 HDMI/USB Cable Replacement, HDMI/USB Cable: passo 5, imagem 1 %32 Dell VRP100 HDMI/USB Cable Replacement, HDMI/USB Cable: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the two 3.4mm PH000 screws from the cover by rotating counter-clockwise.
    • Peel off the tape using your hands or the blunt nose tweezers.
    Pergunte ao FixBot
    Comentar
  6. Dell VRP100 HDMI/USB Cable Replacement: passo 6, imagem 1 %32 Dell VRP100 HDMI/USB Cable Replacement: passo 6, imagem 2 %32 Dell VRP100 HDMI/USB Cable Replacement: passo 6, imagem 3 %32
    • Remove the two 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Hold the HDMI/USB cable and remove from the connection.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Marco Salazar
Membro desde: 10/08/18
381 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G1, White Fall 2018 Membro de Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Membros
Autoria de 12 guias
6Comentários do guia
Hi
Nice breakdown. Would you know where I can purchase a spare cable (I’m in the UK) as I can find nothing online regarding where to buy one.
Thanks
Jason
jason.d.spiller - Responder Compartilhar
Me too, looking for a cable replacement.
Filipi Nascimento Silva - Responder Compartilhar
also looking for replacement cable as mine has twisted up so bad that there is no longer and picture coming through when can i buy the replacement
Tom Powell - Responder Compartilhar
I am also looking for a replacement cable. Could it be soldered on from another cable?
Peter Hindes - Responder Compartilhar
Me too for replacement cable specs please
geebee800 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 47
Ao todo: 2,028
