Ir para o conteúdo principal
Dell VRC100-R Motherboard Replacement
O que você precisa
  1. Dell VRC100-R Motherboard Replacement, Battery: passo 1, imagem 1 %32 Dell VRC100-R Motherboard Replacement, Battery: passo 1, imagem 2 %32 Dell VRC100-R Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
    • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
    • Slide the cover off and separate it from the controller.
  2. Dell VRC100-R Motherboard Replacement: passo 2, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
  3. Dell VRC100-R Motherboard Replacement, Joystick: passo 3, imagem 1 %32 Dell VRC100-R Motherboard Replacement, Joystick: passo 3, imagem 2 %32 Dell VRC100-R Motherboard Replacement, Joystick: passo 3, imagem 3 %32
    • Hold the joystick down with your left thumb to make space for the plastic opening tool.
    • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
    • Slide the plastic opening tool around the perimeter until you can lift the front panel.
    • You may hear a popping noise when you pry off the front panel.
    I found that you can pull up on the joystick to get this plastic piece off.
    mtt5495 - Responder
  4. Dell VRC100-R Motherboard Replacement: passo 4, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 4, imagem 2 %32
    • Grab the joystick and pull away from the controller to remove it.
  5. Dell VRC100-R Motherboard Replacement, Daughterboard: passo 5, imagem 1 %32 Dell VRC100-R Motherboard Replacement, Daughterboard: passo 5, imagem 2 %32
    • Remove one 6mm Phillips #0 screw.
  6. Dell VRC100-R Motherboard Replacement: passo 6, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 6, imagem 2 %32
    • Turn your controller over and orient it so that the thin side is on the top.
    • Remove four 4mm Phillips #0 screws.
  7. Dell VRC100-R Motherboard Replacement: passo 7, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 7, imagem 2 %32
    • Turn your controller 90 degrees clockwise and insert a blue plastic opening tool into the crease of the back panel.
    • Push down on the end of the plastic opening tool closest to you to lift the panel up.
    • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
    • You may hear loud popping noises as the back panel separates from the controller.
  8. Dell VRC100-R Motherboard Replacement: passo 8, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 8, imagem 2 %32
  9. Dell VRC100-R Motherboard Replacement: passo 9, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 9, imagem 2 %32 Dell VRC100-R Motherboard Replacement: passo 9, imagem 3 %32
    • Use the tip of the blue plastic opening tool or your fingernail to gently flip-up the white locking flap.
    • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
    • Grab the blue cable and pull away from the socket.
    • To reinstall, insert the blue cable into the connector and close the flap on the black line.
  10. Dell VRC100-R Motherboard Replacement: passo 10, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 10, imagem 2 %32 Dell VRC100-R Motherboard Replacement: passo 10, imagem 3 %32
    • Use the tip of a spudger or your fingernail to gently flip-up the small white flap holding the orange ribbon cable.
    • Grab the orange cable and pull away from the socket.
    • To reinstall, insert the orange cable into the connector and close the flap on the white line.
  11. Dell VRC100-R Motherboard Replacement: passo 11, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 11, imagem 2 %32
    • Place two fingers on the perimeter of the daughterboard and lift it away from the controller.
  12. Dell VRC100-R Motherboard Replacement, Motherboard: passo 12, imagem 1 %32 Dell VRC100-R Motherboard Replacement, Motherboard: passo 12, imagem 2 %32
    • Remove two black 6mm Phillips #0 screws.
  13. Dell VRC100-R Motherboard Replacement: passo 13, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 13, imagem 2 %32
    • Pinch the black ring on the top of your controller and pull toward yourself to disconnect it.
    • The ring may slightly pop as it disconnects from the controller body.
  14. Dell VRC100-R Motherboard Replacement: passo 14, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 14, imagem 2 %32
    • Grab the black and red wires attached to the motherboard and wiggle the connector out of the socket.
  15. Dell VRC100-R Motherboard Replacement: passo 15, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 15, imagem 2 %32
    • Remove three 3mm Phillips #0 screws.
  16. Dell VRC100-R Motherboard Replacement: passo 16, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 16, imagem 2 %32
    • Insert your finger underneath the black plastic "V" and scoop up to remove it.
  17. Dell VRC100-R Motherboard Replacement: passo 17, imagem 1 %32 Dell VRC100-R Motherboard Replacement: passo 17, imagem 2 %32
    • Remove two 4mm Phillips #0 screws.
  18. Dell VRC100-R Motherboard Replacement: passo 18, imagem 1 %32
    • Pinch the orange ribbon cable and pull toward yourself to remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Steven Pineda
Membro desde: 04/16/18
881 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S18-G3, Livingston Spring 2018 Membro de Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
Membros da 4
Autoria de 5 guias
4 comentários
Thanks, using this as a tear down guide.
Gamerz Crafted - Responder
Hi, do anyone know where this motherboard can be purchased?
John Franco - Responder
does anybody know where I can buy the ribbon cable, between the two boards. in Step 10
Tim Bury - Responder
where can i buy the motherboard?
José Yoctán Leyva Román - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,439
